Any recommendations on the best way to configure and wire leaf battery modules for a 144 volt system, and be able to use a BMS to monitor the batteries? I thought I could buy the 14 unit setups you see all over eBay (7 modules in series, with another 7 in parallel). That gives ~52 volts. Then I thought I could wire 3 of these in series to give me ~150 volts.
I'm told (by the helpful people at evolve electronics) that a BMS would not be pheasable with this setup tho.
Is there no way to setup the leaf modules for 150 volt 132 ah setup? Without tearing them apart, or crazy wiring all over the place?
Thanks for any advise here!!!
Jeff
Jeff
