UCC28070
To test input Voltages into these ICs, which can be done safely now that I know what Pins they map to on the PFC connector CN2001.
- Pin 2 - Rrdm = 137 kOhms
- Pin 4 - Vsense = TP2164 = 13 kOhms to GND (DC-) = Rb
- Pin 4 - Vsense = TP2164 = 3.42 MOhms to Drains of Q100, Q101 = Ra
- Pin 4 - Vsense = TP2164 = 1.95 MOhms to Drains of Q102,Q103 = Ra
- Pin 5 - Vinac = TP2165 = 1.579 MOhms to Vin = Ra - it's weird these values are different even though the Typical application doc says this should be the same as Ra above.
- Pin 5 - Vinac = TP2165 = 13 kOhms to GND = Rb
- Pin 6 = Rimo = 55.5 kOhms to GND
- Pin 7 = Rsynth = 80 kOhms to GND
- Pin 8 = Csb = 491 ohms to GND
- Pin 9 - Csa = 491 ohms to GND
- Pin 10 = Pklmt = Rpk2 = 9.16 kOhms, meaning should be Rpk1 = 2.84kOhms, but Rpk1 = 6.92k and Rpk2 = 9.2k
- Pin 13 - Vref = TP2149 = 12 kOhms to GND = Rpk1 + Rpk2 = 2.84kOhms + 9.16kOhms
- Pin 14 - Gda = TP2147 = 21.2 kOhms to Gate of Q102, Q103, Q100 and Q101, Pin 14 to Pin 17 is 42 kOhms, through R174 (509 ohms) to "In A" of MCP1404E
- Pin 15 - VCC - goes to Pin 7 of PFC connector (CN2001)
- Pin 16 - GND - (Pin 17,15, 9, 10, 8, DC-)
- Pin 17 - Gdb = TP2148 = 21.2 kOhms to Gate of Q102, Q103, Q100 and Q101, Pin 14 to Pin 17 is 42 kOhms, through R176 (509 ohms) to "In B" of MCP1404E
- Pin 18 - SS = TP2146 = 838 kOhms to GND. C122 to GND Doesn't got to PFC connector to be used as an external fault stop.
- Pin 19 - Rt - sets the switching frequency = 90kOhms to GND
- Pin 20 - Dmax = Rdmax = 95.3 kOhms to GND
