Yes I do! And no problem, very easy to fix the resolver offset coding,
The commands are soon coming to Leafspy Pro!
I was literally about so say "Dala knows how to do it"Yes I do! And no problem, very easy to fix the resolver offset coding,
Hi, should I load Leafspy pro on a cromebook or my applephone? thanksYes I do! And no problem, very easy to fix the resolver offset coding,
Has Leafspy pro have the new command to fix the resolver code? thanksYes I do! And no problem, very easy to fix the resolver offset coding,
I haven't used Leaf Spy for some time, so I can't tell you. Sorry. My Leaf parts are boxed up at the moment.Has Leafspy pro have the new command to fix the resolver code? thanks
