So I took the jump and bought a 'totalled' 2013 Leaf with 37k miles, and a battery health of 89% and 247Gids at full charge and 89% SOH. Really gonna be a shame to scavenge this car, it's in really pristine condition except for the rear corners. Oh well.
I'm gonna try to swap in the Leaf motor and reconfigured 24kwh battery into my '87 Samurai Samurai. I'm hoping to bolt the motor directly to the 5-speed transmission and transfer case. I'll be using the transmission and transfer case out of a newer Geo Tracker instead of the Samurai units because that transfer case is gear to gear for the output and substantially noisier than the gear-chain-gear affair in the Tracker.
The weight of the Samurai as pictured is right at 2,300 lbs. I figure that the Leaf motor and Suzuki 1.3 gasser are roughly equal in weight. Adding in the Leaf battery I hope to have a working on/off roader with roughly 50 miles of range. Since the dunes I took the picture on are only 5 miles from my front doorstep that should be more than enough?
Any thoughts on mounting the motor to the trans?
Some people have suggested getting rid of the trans altogether and mounting the motor directly to the transfer case but that would probably (?) require regearing the case and maybe the front and rear differentials to get the motor to spin at the correct speed? That's why other people who have done this same swap have said "keep the transmission" and just leave it in 2nd".
Any thoughts on any of this?
