1 - 5 of 5 Posts
Does anyone have the wiring diagram for the Leaf shifter. It seems it is not in my service manual. In particular, I want to know how to use it in the truck (no leaf wiring harness), just direct to Pauls board, if possible. I get an open circuit on all the wires even when I move the shift lever.
It looks like the Leaf is using a Hall-effect sensor which requires a 5 volt excitation in order to send an output when the magnet moves to the various positions. It is not clear from that schematic (no labels) which lines are the excitation and return, and which are the output signal.
Maybe someone will chime in with the wiring labels.
1 - 5 of 5 Posts
