We've done a few vehicles now using the second gen leaf kit.
Just plug it all in on the bench/floor.. get it working and then remove as much as you can.
The minimum we have found that works is:
Complete motor stack without AC (harness unmodified) including the park lock actuator.
Main ECU (VCM)
BCM
IPDM
J1772 inlet
Chademo inlet
Water pump
Coolant temperature sensor
Brake pedal switches (not the brake pot)
Accelerator HEPA
Start button and encoder
Two key sensors (both dash area, one above hvac and one in centre console)
Telematics module
Key security module (the bit welded to the dash crossmember)
Two original relay boxes from the engine bay harness
Repackaged HV battery with standard BMS
Heavily modified dash harness (with interior fusebox)
Body harness stripped down to just HV battery comms connector
The key
Prndl (gear selector)
Prndl light
Binnacle lower part
Sent from my SM-N9005 using Tapatalk
Main ECU (VCM)
BCM
IPDM
J1772 inlet
Chademo inlet
Water pump
Accelerator HEPA
Telematics module
The key
Prndl light
Binnacle lower part
