1 - 4 of 4 Posts
Works perfectly. Whatever command you send to the first one the other on does the same. Down side you can not control independently as because there the same address.
Where in the document does it say it can support up to 4? I thought it was specifically only 1 lear charger using the EVCC. I was thinking about using 3 in my build but I don't think it's been tested or confirmed to work (I plan on using Orion BMS CAN bus editor instead of the EVCC).
1 - 4 of 4 Posts
