Hello, experts:
I've got an older Duffy Electric Boat with a 48V system using 8 X 6V GC2 FLA batteries rated at 220Ah in series. These batteries are getting close to end of life and are beginning to weaken, so I'm wanting to convert to LifePO4 (LFP) batteries to enjoy longer life, less maintenance, and reduced weight. The boating range provided by the current FLA battery pack is sufficient for my needs on an inland lake, and I live in South Carolina, so winter cold will not be a problem with the LFP batteries. The motor is a 48V 5hp DC motor, and the controller is a Zapi 350A 48V controller
At this point, I'm considering using 4 X 12V 105Ah LFP batteries in series from Lion Energy Lion Safari UT 1300 - Lion Energy These batteries have a 1344 Wh rating, which is similar to the 1320 Wh rating of the FLA batteries. Does this approach seem reasonable?
I have 2 additional questions or issues:
- Using 4 X 12V in series is essentially a "drop in" replacement for my boat, in terms of wiring, space and layout of batteries, etc. This works well for me from an installation standpoint, but I've also been told by another battery supplier that a single 48V battery is preferable, since the BMS's of 4 individual batteries in series will not necessarily charge and discharge the batteries equally. Is this a valid concern?
- I currently use a Delta Q charger with a Trojan T105 FLA charging profile, but I believe it has an AGM charging profile. Would this be an acceptable charger for the LFP batteries, especially considering the higher charging voltage of the AGM profile? I've recently acquired a Delta Q charger that is supposedly a lithium ion charger for EZGo golf carts, but I haven't yet been able to confirm the actual charging profile programmed into this charger. I'm not convinced that it's anything other than an AGM profile. Your thoughts on either charging approach?
Thanks very much for your advice and insight into my little project!
