1 - 2 of 2 Posts
I finally got a Link Pro installed and wired up in my EV. However, it seems that this version of the meter does not display KWh, Only AH.
I looked in the manual for the Link-10 and E-meter and they clearly show a setting to display KWh. Didn't see it in the LinkPro manual.
Any one find a way to get the Link Pro to display KWh?
Thanks
Mike
evalbum.com/1844
Thanks
Mike
evalbum.com/1844
ndplume, you are correct. The new Link Pro will not calculate watt-hours. The older Cruising Equipment and Xantrex E-Meter and Link 10 will calculate watt-hours, but won't count the watt-hours down to zero when charging, as the AH function will.
I use a Link 10, new-in-box, which I purchased on eBay. The older E-Meter's and Link 10's are highly sought after. I found a-new-in box E-Meter in my stash yesterday. I'll be selling it in the Classifieds.
Russ Kaufmann
RUSSCO Engineering
1 - 2 of 2 Posts
