O.K. What are your results? Start us offI want to start this thread to compare Lithium Battery, based on personal experiences.
Let try to keep this compact, so it would be easy to use it as a reference later.
Thank you all in advance for all inputs!!!![]()
I would like to see reports of cell failures with damage caused and causitive situation and including BMS systems used. [Working fine with total kW-hrs delivered is also good to report.]O.K. What are you results? Start us off![]()
O.K. Cool. You want a comparison of members experience with different Lithium batteries. How about you start a spreadsheet and we'll fill in? I'll start. Kokam 40 Ah perform to spec up to 8C and have 19 cycles in the field with no problems.I think info based on personal experiences will help to promote EVs in general... In our design we should include some kind of Li battery and not AGM or other lead-based products, they are history.
Not even for 8cek?I never draw abowe 2C from the pack.
I used this also.. I have two points to consider. It works well on the sides of battery boxes. If you are putting it under lead acid, don't waste your time...the weight of the battery will flatten it pressing the air out of the bubbles. Be careful getting it anywhere near the top of the battery also...yes, aluminum foil is conductive. It took me a while to figure out why I was getting a tingle off my truck frame when touching battery terminals. I covered 4/0 with some heater hose (reinforced with steel) and it was touching the aluminum foil bubble wrap...PM, you might try this stuff in the link below to retain heat in your batteries. It's only about 10mm thick and is equivalent of about 50mm of fiberglass insulation or 25mm of foam insulation. I used this stuff in the construction of my office. It also lines the floor of my truck and is in the wall behind the seat. This is a double layer product but they make a single layer half as thick which is what I used.
FYI I've used it in the ceiling and floor of my home. After installing it under the house which was normally comfortably above freezing in the winter, it became very cold under there. It works by reflecting radiant heat just as a mirror reflects visible light. It was developed by NASA, the US space agency to minimize the insulation thickness in their space suits which otherwise they said would have required several inches of insulation which wasn't practical.
I seriously recommend this stuff to everyone!
http://www.radiantbarrier.com/side-wall-insulation.htm
And this link :I covered 4/0 with some heater hose (reinforced with steel)
Thank you for sharing this info. Did you try to go 2C "normal" discharge or more then 3C?What they say in brochure is correct 1C normal discharge, 3C for 15-20 even 60 seconds. I haven’t experience any negative yet, and car is running every day for the past year.
