1 - 20 of 155 Posts
Premium Member
I've decided to try and work out the cost comparisons for a Lithium pack vs a Lead pack for a set range and a set number of years. Is Lead Acid actually cheaper or does is just seem that way up front? This article aims to find that out. The method is to get 10kWh of usable energy, I’ll try to get that with Lead and with Lithium and see what we find is cheaper in the long run. Assuming an efficiency of 250Wh per mile (a compact car) we should get a range of 40 miles (65km) with either pack. I’ll be using Australian prices since I’ve already researched them, but the comparison is probably close in other countries too.
Product Technology Electronic device
The first step is to source a lithium pack with 10kWh of usable energy. The Lithium batteries I have chosen get 2000 cycles to 80% DoD and I estimate that at the 1 hr rate they will deliver 95% of their rated energy due to the Peukert’s effect. So to give our total energy we multiply our usable energy by 1.35 meaning we need 13.5kWh to get out 40 mile range with lithium batteries. If we assume a 120V conversion this means we need 112.5Ah. The cheapest Lithium batteries I have seen in Australia are Thundersky LiFePo4 LFP prismatic cells $2.50 per 3.2V per Ah. So our 13.5kW pack would take 38 3.2V cells at ~110Ah and would cost $10450 at normal prices (no group discount), without shipping or BMS.
For a Lead Acid pack we also need to keep the batteries at less than 80% DoD and at the 1hr rate we can only expect to get 55% of the rated energy of the pack back due to the Peukert’s effect. That means we need to multiply the usable energy by 2.25 to get our total energy, in this case its 22.5kWh. Trojan T605 batteries could make up a 22.5kWh pack with 18 batteries (108V, 210Ah) at $225 each or $4050, it didn’t say how many cycles it would take on the website but let’s guess around 650 to 80%. That means we’ll need to replace our lead Acid pack around three times for every lithium pack we buy, meaning our total cost for the lead packs goes up by a factor of 3 to $12150 over 2000 cycles.
Now I must admit that I didn’t look very hard for the cheapest batteries and I am only guessing the cycle life of the Trojans but even if it’s not precisely accurate it does show that the myth that Lead is clearly cheaper than lithium is not well founded. Lithium’s greater efficiency and cycle life makes up for its higher initial cost. I didn’t know what the results would be like before I started. The10kWh number was chosen just to make it easy to calculate, it has little influence on the result one way or the other. I thought the results would be close but not this close. Please note that the Lithium pack would require a BMS, which would cost $1270 but that still means you are going to pay around $12k whether you go with Lithium or Lead. It would also be worth mentioning that you would be paying for more electricity over that time with Lead; 36MWh costing $3600 compared to 21.6MWh $2160 @ $0.10 per kWh and recharging 80% of capacity. You would also need to water the batteries if you went with the Trojans, while the lithium’s would be maintenance free. It’s also worth mentioning that there are apparently disputed copyright issues with the thundersky cells and their previous record with customer support apparently not good, but this was just a cost comparison and the number look pretty convincing.
The total cost per km for the 2000 cycles is $15 750/ 130 000km = 12.1c per Km (19.7c/mile) for Lead Acid and $13888/ 130 000km = 10.7c per km (17.4c/mile) for the LiFePO4. These would obviously increase slightly when factoring in tire and brake wear. Just for comparison a the cost per km of a bunch of small ICE cars are listed here the cheapest being 41.44c/km but only 33.5% of that cost was for fuel and servicing (the rest being common cost for EVs as well) so that’s 13.9c/km for the cheapest ICE using fuel at $1.25/L. Clearly then EV have a price advantage over ICE’s especially now that normal unleaded is averaging $1.48/L.
In summary, while Lead Acid may be cheaper up front new lithium packs are more cost effective in the long run as well as being lighter, smaller and maintenance free. Obviously battery choices are highly dependant on individual conversions and budgets but it should not be assumed that Lead is the budget option, since it’s just not true anymore.
G
Discussion Starter · #2 ·
set number of years
For lithium this is not a know thing. For lead it's pretty much a given but it still depends upon how well you care for your batteries and how deep you discharge them. I know that for me even changing out lead every 4 years would be far cheaper than lets say one pack of lithium for 10 years. My lead pack only costs me about $800. So $800 times 4 equals $3200 for 4 packs of lead vs one pack of lithium for around $15,000 for the same size pack. Pretty easy to figure out the cost. That assumes that you can actually get 10 years out of a pack. Shelf life vs charges are totally different. I may get to charge and discharge thousands upon thousands of times but I my only get to do that in a short time frame. I have heard that the shelf life of lithium is not so hot. So shelf life is the real factor here and not how many times I can charge and discharge. I'd still rather spend $3200 for a few packs of lead than $15000 for one of lithium. Still a big difference. Granted the lithium would be lighter but still not worth the expense yet. Soon! Maybe something better will arise that has not been spoken about. : )
Premium Member
But are you comparing the same range for the two packs? You can buy lithium without getting a 100 mile range, people seem to overestimate their lithium sizing and payback time. It doesn't bother me if you go with lead, that your choice, I just want people to look at the actual comparison not just 100Ah of lead costs this much 100Ah of lithium costs this much. There is more to it than that...
I think one of the main things you left out of the article was a weight comparison. 18 lead batteries at about 50lbs each would weigh 900lbs. Not sure what the carrying capacity of a compact car is, but you would probably not have the ability to carry much of anything else without a suspension upgrade. What would the cost of upgrading the suspension be? What are the effects on the cars handling by adding this much extra weight? What is the weight of the Lipo's? We can't discount these factors.
Also, as someone else said, I agree that shelf-life (as well as total cycles) should also be taken into account.
Yes that's a good point, you don't need the same amount of Lithium as lead since lithium has more usable energy, plus the fact that you are dragging around less weight with the lithium.
Or you could drag around LOTS of Lithium but get a serious range. 100 km or more would be VERY nice, but doesn't seem very realistic with led, at least not if you want to go at highway speed too.
I've seen a number of conversions on EValbum.com that got 60 mile range and 70 mph top speed.
My 2 cents
is 2000 really a realistic number? what if you start having cells die after 500 or 1000? then what?
The cycle life is similar among many different companies using the same LiFePo4 chemistry. With the proper BMS, 2000 cycles should not be a problem as that assumes 80% DOD every time.
What would that proper BMS be? While we have standardized controllers and motors and chargers for EVs, I have yet to see a true BMS "product" out there that has a published pricetag that you can just buy. It's really the missing link.
The BMS is the core of the debate. The issue with lithiums is they need to have a closely coupled battery management system which is quite complex since it needs to monitor the batteries on a cell by cell basis and therefore expensive.
Over time the cost of the BMS and the lithiums will clearly reduce while the cost of oil and lead-acid batteries will clearly increase. However right now we need a good, proven BMS for lithiums to progress putting them into cars. Does anyone know of a good BMS out there?
Premium Member
The BMS was included in the calculations. There is a link to it in the blog. The cost for a 10kW pack was AU$1270. $350 for the master module and $24.20 per 3.2V unit.
Good point Matt and quite true however I guess we are changing the argument on you from cost to availability. Can you describe your BMS supplier please, how it works, and why you think it is reliable? Don;t get me wrong, I would be delighted if you can point me to a good Lithium BMS solution
If you go to the metric mind website you can find a good BMS system. I don't believe that prices are on the website, but you can drop Victor a line and find out.
Most contacts I have located in china supply the BMS with the battery. All it has to do is cut off voltage and amps above and below certain parameters, not very complicated.
Premium Member
I haven't looked into it that much specifically- you can email him if you want more info. To be honest I just trust the person who recommended them to me. I can't really comment on how good they are because I haven't got mine yet. ;)
Matt, I have to take issue with the most critical item in your discussion:
You picked a situation that severely confounds your results. Your use of Australian Trojans at the extreme price of $225 AUS makes your comparison easy.
Trojans are expensive. Lead Acid in Australia is extremely expensive.
Let's try some US based Trojan T-105s from here:
http://www.thesolar.biz/Trojan_batteries.htm
Same voltage. Same Ah rating. Price USD is $127 each. So your pack price is now $2286 for 18 batteries. 3 sets cost you $6858 USD.
See? Just by shopping around your argument kind of falls apart.
And in the US I haven't gotten to the Eveready GC2 golf cart battery from Sams that only $75 USD each. That's a full 1/3 of the price of the T-605s that you originally quoted. Same voltage and same Ah rating as your T-605s.
From a technical standpoint Lithiums are better. There's absolutely no dispute about that. However at least in the US lead acid is definitely a fully available option on the table because lead acid packs are available at a small fraction of the cost of lithium.
ga2500ev
Does anyone have a 10 year or even a 5 year old laptop with original batteries that hold a charge anything like they did when they were new? Or how about a rechargeable drill? Just curious since I have always seen a huge drop off after just a couple years. Norm
As a Lead-acid EV owner who's joined the ranks of realization that their EV does not provide the distance that that they would like...
I've tried to create a wiki page of all the alternatives to lead-acid on this site, and for each specific option, detemrine the cost of a 10KWh pack. (10KWh is arbitray, but it would get me to work and almost back.)
The link is at
http://www.diyelectriccar.com/forums/showthread.php?t=13351
This has been a disappinting collection of research until i found the latest lithium entry, which is:
Ebay Ping is only selling on ebay, but offers a pack with BMS: 48V 20AH for $840 (10 packs = 9.6KWh @ $8400) Ping doesn't recommend series/parallelling of pack. Not sure of who manufacturers the cells, and no cell data. Here is a testimonial on a bike.
Note the price point: $8400 for a 10 KWh pack, which is a good price point. Lithim is the holy grail EV batterys. The problem is paralleling these packs for EV use. I'm working on trying to find someone who has successfully done that. If you know of any... please pass info along.
Mark.
http://www.evalbum.com/1352
The link is at
Ebay Ping is only selling on ebay, but offers a pack with BMS: 48V 20AH for $439 (10 packs = 9.6KWh @ $4390) Price point is best I've found. Ping doesn't recommend series/parallelling of pack. Not sure of who manufacturers the cells, and no cell data. Here is a testimonial on a bike.
Note the price point: $4390 for a 10 KWh pack, which is about 1/3 of other Li-ion prices. This has the greatest promise of the holy grail EV source. The problem is paralleling the packs for EV use. I'm working on trying to find someone who has successfully done that. If you know of any... please pass info along.
Mark.
Do the math again. That's a 10khw pack of 20ah cells. You'd need 5 of these to get good EV range which would be about double what you can find elsewhere with 100ah bricks.
1 - 20 of 155 Posts
