Deja Vu!Well if you cannot afford to pay for the panels, you cannot afford to replace batteries every 3 to 5 years either. Off grid solar will cost you 10 times more than buying the power. And if in Canada, even higher.
*cough* mWh/year *cough*I found non ( no ul cert)grid tie pannels thin film , for $.99/watt 1400 watts will get 10,000 miles/year with out losses. used forklift batteries , big ups batteries used , used ups sine wave inverter 3to 5kw $200 , new charge controller $500 (Outback). 1400 watts/hr.X5.9 hours / day avarge (north cal ) X 280 days per year = 2,312,800 watt hrs. / year ( 2.3 mega watts/year)
how many cells / battery ? 6 cells= 12 volts I have a old forklift battery 2000+ lbs , 24 volts , 2000 amp hr. 48kwh if new ( or .048 mega watts LOL)I have serious doubts about that. FLA batteries energy density are around 30 to 50 wh/kg. So how much does each battery weigh? 32 volt @ 650 AH they would have to weigh at least 420 Kg or 920 pounds each @ at the extreme high end of energy density of 50 wh/kg.
I believe you said they weigh 325 pounds each or 147 Kg. If they are 32 volt @ 650 AH would be a density of 140 wh/kg. So you are telling us a FLA has a higher energy density than LFP of 100 wh/kg? I seriously doubt that.
I am familiar with RR 32 volt batteries and Rolls Surrette makes a 32 volt 660 AH battery but it weighs in at 1240 pounds or 37 wh/kg. You must be seriously mistaken with either the weight or AH capacity
haven't worked with megs before : 1,000,000 watts = 1 mega watt . 20 times better batteries and we will be carrying megs in our cars and my diesel pickup carries about .9 mega watt hr. of output . 80 gallons x 15 hp/ gallon (net ) or 2.7 megs gross .*cough* mWh/year *cough*
I'm just teasing.haven't worked with megs before : 1,000,000 watts = 1 mega watt . 20 times better batteries and we will be carrying megs in our cars and my diesel pickup carries about .9 mega watt hr. of output . 80 gallons x 15 hp/ gallon (net ) or 2.7 megs gross .
I was not trying to be hard on you, at least not too hardI could very well be wrong on weight and Ah.
