1 - 1 of 1 Posts
Selling LogiSystems Controller has the following specs:
  • 120-144V nominal voltage input
  • Includes two fans (not pictured)
  • Dimensions (LxWxH): 12.5" x 6.75" x 5"
  • Weight: approximately 9lbs
  • Built-in heatsink - no external heatsink required
  • Three adjustments - ramp (acceleration), sensitivity and range of current adjustment, and motor current limit
  • Uses 0-5kohm potentiometer as throttle input
Price: No less than $1200 unless you get it on Ebay for less (see below).
This has NEVER been used other than bolted into my EV for about a week. It was sent to the factory for checkout/reman to ensure that it is 100% perfect. I decided on a different controller and sent this back to LogiSystems. Warranty from Logisystems. I have seen these controllers go for about $1800.00 new.
Like new other than scratches on two (out of 4) of the bolt holes.
On Ebay: http://cgi.ebay.com/ebaymotors/ws/e...n=2&item=120416835948&category=6763&viewitem=
1 - 1 of 1 Posts
