1 - 20 of 23 Posts
Impressive numbers...enough to be suspiscious...
I suppose everyone else who has tried making a 5:4 HP:LBS ratio motor has been silenced before they made it to market?
"Yuneec is a young, progressive, forward thinking company"
I usually read that as "inexperienced, buzzword-filled, imaginative"
Humm!!... Curiously interesting!!
Motor spec = 1.2 to 1.5 HP per lbs peak..... Good ratio!
And in a realistic voltage range (- 200v)
But the RPM seem low for that much power!! 180 lbs-ft for an 11 diameter motor with REALLY short lenght (8.25")?????
Anyway, I need two... what is the price?...:D
4 of those (1 per wheel), each running through a 4:3 reduction gearbox (a planetary unit on the end, perhaps, if length is an issue) would give a total of 324HP and a top speed of roughly 96MPH (155 KPH). Not too bad, but I'm not seeing a torque figure, and seeing as these motors are meant to drive propellers (and so not having much in the way of drag) that could be quite the limiting factor.
I emailed him, I will let you know...
Propellers are a never unloaded . air or water they work much harder then a auto .
The 60kW version says 2400 rpm, so the torque = 60,000/(2400*2pi/60) = 238 N-m, or 175 Lb-ft.
Admin: 'one of many'
Well, assuming that same 4:3 ratio gearbox you'd have 233 lb-ft, with one on each wheel making a total of 933 lb-ft of torque.
Given that a 2011 Mustang with it's V6 engine gets 280 lb-ft, one wheel is pretty much comparable. So that's very good indeed.
Don't forget.... the 280 lbs-ft of the Mustang motor need to be multiply by the first gear ratio and the rear diferrential ratio..... 280 x 10 (around) = 2800 lbs at the two rear wheels.
For what it is worth the copywrite on that page is 2008. I think we would have heard more about them in a two year time span.
There are othe sources for these type motors though. There are planes flying with electric motors. There are a couple of you tube videos on them.
I could call them I guess. Some companies do not answer emails. From what I understand a light plane is scheduled for production with these motors that will be used for flight training. I remember when I first learned to fly as a teenager it took most of my money to pay for a couple of hours each month. I can see how electric would cut down on that some but not much really.
I believe the company is genuine – if you do a youtube search for Yuneec there are several videos showing various motors on test in paragliders and light aircraft.
There's a company in Slovenia that produces similar motors. They look to have great potential, but getting hold of a suitable brushless controller appears difficult. They're supplied by another company that doesn't seem keen to sell on a one-off basis.
http://www.enstroj.si/
1 - 20 of 23 Posts
