I purchased an electric kart from a kart shop in California. They work with gas karts, and knew absolutely nothing about it. Someone built this kart exactly like it sits, and I really want to get it moving.
I have since been able to figure out the agni 95r motor is good, and so is the Alltrax axe7245 controller. I just need to add the juice!
The controller programming was set to 60V low shutoff, 90V high shutoff, so I assum they were running 72V.
There are 2 battery boxes wired in parallel, so both boxes will need 72v. They each measure 19" long, 5- 5/8" wide, 5- 7/8" tall.
The agni 95r shows a continuous 230A rating, 400A max. 18650 cells do not put out enough A. I'm trying to get as much run time as possible from the space I have.
Im open to suggestions! Just please don't open the debate about how this agni is going to fail, why I didn't use xyz controller, and how expensive these batteries will cost. This is my first electric fun toy, and I really just want to play!
Thanks in advance!
Thanks in advance!
