Winston.justevs.com
Sent from my SM-N9005 using Tapatalk
This would be the typical small pickup conversion, but with modern battery (many pickups are older, using lead-acid). Keeping the transmission, the motor would be in the location of the stock engine, along with the controller.Hi Eco
Small pickup truck, -
11 inch forklift motor
Paul & Sabrina Controllers
Batteries from a Chevy Volt
Have a look at my thread
http://www.diyelectriccar.com/forum...dubious-device-44370p15.html?highlight=duncan
The main difference is that you will want to keep the gearbox and you don't need as much power
get a smart and put a trailer behind it
- remove the engine and rear suspension of a Smart ForTwo, attach an extension frame with box on it and a drive axle under it
- okay, this might be a little silly, but there must be some use for a Smart... and the car would make a small cab for a truck.
