1 - 14 of 14 Posts
Having bought a motenergy ME0810 with Alltrax controller from an auction site that was brand new still in its box, but with no specification information. I was going to use it for a new car design project that never happened, a friend said how about putting it in the Lotus and see if its powerful enough. I was wondering if the motor would be powerful enough?
I'm currently converting my 1982 Lotus Esprit S3 to electric using a Nissan Leaf motor with home built controller. The Leaf motor has less power (80Kw), but more torque which is more important for decent acceleration. Googling your motenergy ME0810 motor, it appears to be only 15Kw and very little torque, so I would say, not nearly enough power/torque - I thought the Leaf was marginal!
I am very interested in your project, sounds amazing. I am looking just for town driving on the motor and also do not want a high voltage system, that's why I decided to go for a 48V system. I have other plans to power the car above 30-40 mph to motorway speeds. I think the motor should be capable of lower speeds, what do you think?
Are you planning to mount it to the existing gearbox? I guess your motor might be enough to get the Lotus moving, but I suspect you may find it really slow on acceleration, even in town. What are you planning for the higher speeds?
No I won't use the existing gearbox, a belt or chain drive direct to a differential using the original drive shafts, so the gearing will be a single sprocket.
I have designed a 110bhp turbine to use for higher speeds and will have two in total so 220bhp.
I want to keep the design simple and as light as possible.
What Matt is saying is that a turbine-electric hybrid is not simple. I agree.
Without the proposed turbine engines, and with only the ME0810, the car would be like a golf cart. Why would anyone want an Esprit golf cart?
just to confirm, what rpm are your turbines spinning at? usually they're much higher than a regular gearbox can handle
True, and due to the high shaft speed and the terrible inefficiency of turbines running off of the ideal speed and load, the best way to use a turbine engine in a vehicle is in a series hybrid configuration. A series hybrid requires big motors, not a weak one.
Discussion Starter · #11 ·
The electric motor is being used more like a starter motor. So far the prototype turbine runs very well with no problems so far. As a designer it's very frustrating as your head is always full of ideas, and you need to get them out of your system so to speak and try them. If it all fails then it's back to the drawing board.
1 - 14 of 14 Posts
