Hi everyone,
I recently purchased a set of love joy couplings before realizing that it wouldn't work out because it was too small for the Warp9 motor I'm using. Here are some pictures to show what I'm talking about:
The motor shaft is too long for the coupling so it sticks out (shown in first image) so when I put the second part of the coupling on, it doesn't sit all the way on properly leaving space in the middle (shown in second image). If I lift the bottom up, then it fits properly but it's elevated from the motor (shown in third image). If I put a key in and used the hex screw to jam the key in place, would that keep the coupling safely elevated and connected or is that not reliable?
My other option is buying a whole new lovejoy coupling that is larger. I've been looking on eBay and I can't seem to find the right one though. The Warp9 motor shaft is about 30mm tall so the coupling needs to be at least that tall. And the coupling can be 95mm in diameter maximum because that's the size of the small circle platform that it's sitting on. Please let me know if you have any links to lovejoy couplings that I can buy or if there's any way I can make what I have work.
Thanks,
Sifa
Thanks,
Sifa
