Hello group. Im working on a small farm tractor, for weeding in rows. Have found a Fiat 211 with the hoe underneath. Really nice. Motor is 36volts. Rated at 3hp continuous. 80Amps.
Instead of buying a 36v charger, or 3 12 v chargers, would it be possinble to use a car type alternator (lying on my shelf), 12v 80 Amps. It will be driven by an AC motor (also on the shelf) from the outlet in the barn.
The plan is to get a cheap and reliable charger. That will give the right charging pattern.
Also from the shelf, a 100A fuse and an on-off switch, which will have to substitute a controller for the testing.
Another 100A on-off as emergency switch, in case the stop-go switch should weld stuck...
About Amps. Will a 100Amp fuse work equally well with any DC voltage; 12, 24, 36 and so on? It will still burn at 100 Amps?
Cheers from John in Denmark
