1 - 20 of 31 Posts
Hi folks.
In this thread I'm going to present an all hardware DIY (Tesla) ACIM ASIC controller that does not need uC, DSP and programming.
It is a spin-off of this thread about a similar controller for a DC series motor.
Most of "can it be done?" stuff (simulations, breadboarding) is in the DC series thread. You may want to read it before continuing here.
Only one feedback signal is needed: a tacho signal. Let's assume that the Tesla ACIM drive units have encoders that generate 36 pulses per rev, per channel.
That means 2 (channels) x 36 = 72 tacho pulses. With a frequency doubler (edge detector) 144 pulses are available for control.
The basic design in the DC series thread assumes 60 pulses per rev from a 2 pole machine with a reluctance sensor.
The Tesla ACIMs could very well be 4 pole machines, so 144 from an encoder is great!
Even a DSP based controller needs tailored interfaces for a specific drive unit. And then some software mods.
So it takes less effort to modify an all hardware controller that can be divided in well defined functional subcircuits,
like PLL, throttle, PWM, phase shifter, tacho (encoder), output stage.
For the 60 to 144 transition it means: set the division factor in the PLL to match the higher input frequency.
That's all. The parts count remains the same.
Two pole is fine too. I didn't want to use the word "universal". ;)
Focus is on Tesla ACIM drive units.
But as a demonstration of the versatility I'm going to start with a two phase (commonly referred to as single phase) induction motor.
It will have three half bridge PWM legs though. The two windings will be connected between the legs. Phase shifts of AC at the legs: 0, 60 (-60 for reverse) and 180 degrees.
Description can be found in the Microchip application note AN967. Implementation will be in HW, not in SW with a PIC16F72. :cool:
Discussion Starter · #4 · (Edited)
The backbone is the basic control method from the early years of inverter design.
Unfortunately, there's no "programming free" solution yet for 3 phase ACIM with a low parts count.
So what does it take to build an inexpensive DIY Tesla FDU controller with a low parts count?
I think this comes close. Start with a basic control method. Nothing fancy.
Like the original Tesla controller board it is a CANBUS based solution, but with a basic control method.
And a duino compatible motor controller. Lots of free software and modules out there really help to reduce the programming effort.
The CANBUS ensures that more advanced control methods can be implemented by adding controllers to the bus.
I'm going to use this approach in my SiC inverter design. High power 100 kW+ SiC inverter
So this thread ends here.
· Administrator
Tony - Since you've last updated development, there has been significant interest in cheap AC inverters (also, me included!).
An affordable DIY inverter option still seems to be the missing connection.
I don't know enough to do anything other than get in the way, but just wanted to let you know that you completing this and sharing your design is helping others. I'm likely to be one of the first people that jump aboard to build one when it's ready-ish. Glad to see you've picked it back up again.
Thanks, Matt. I'd like to remind you: my projects are for my personal use only and for evaluation of (basic) DIY methods and new technology.
Don't expect results anytime soon.
Report from Ireland: Tesla model III hardware can't be used for testing.
Well, they're on their own if they copy or steal it.
You don't think Tony Bogs is my real name, do you? It's my "alter ego" on the web. Don't want some part of one of my designs ending up in a dodgy product with my real name attached to it.
Back in 2007 I had a first stab at a basic controller design after reading something about a titanate li-ion battery from Toshiba. That proved to be quite tricky back then.
It took twelve years to get to this first design that is going to the foundry. It's a programmers proto board for the model S FDU.
I'm going to use it with a low power SiC (10kW) stage during the programming phase.
The control method can be retrieved from the all hardware design.
Programming and CANBUS communication: Raspberry Pi + PICAN2 + low impedance ICSP interface.
Here it is.
Since the "no programming" Fairchildsemi AC controller chip has been discontinued, the only other option is minimal "uC and programming".
I've found a MCU that fits the bill.
Most of the bit banging (getting the right bits and bytes in the MCU registers) has been done.
I've thrown out all of the silly stuff in the very popular AR-tistic DINO for U IDE. The wire strings are gone.
What is left is basically an empty CORE file folder as part of a definition of a custom board.
The basic header framework (register definition etc.) of the MCU manufacturer is still there.
In order to create a solid reference starting point, the controller has been designed to serve as a replacement board
in a small (front) drive unit of a very popular "S" sedan.
What remains of "programming" is copying the control method from the "all hardware" design.
For instance:
PLL >> MCU TIMER CAPTURE
PWM COMPARATORS >> MCU POWER STAGE
SINE WAVE GENERATION >> TABLE (MADE WITH PHP7 CLI)
PHASE SHIFT AND SLIP CONTROL >> 3 ADDITIONS in "C"
THROTTLE CONTROL >> 1 EXPRESSION
OVERLOAD (HYSTERETIC) CONTROL >> 1 CONDITIONAL EXPRESSION
FAULT SHUTDOWN >> HARDWIRED IN POWER STAGE + ISR
Later on CANBUS communication can be added. Again: very little programming needed, most is done in the MCU CAN hardware.
I'll release a binary file and gerber files as soon as possible.
Image of the ECONOMYFDU board. ECONOMY as in:
- basic
  • inexpensive (US$200)
  • high efficiency control method
This is a thing of beauty:) On one very early attempt at removing the melexis sensors I wrecked one of them and did manage to get two htfs800p to fit with some trimming.
Discussion Starter · #15 ·
Darn, I missed my goal. I am not aiming for beauty. And there's no rush to get to version 1 . And then maybe 2 , 3, 4, .... :)
For instance the latest modification. All active parts on the board are now automotive grade and all parts have an extended temp range of at least -40 to 125C.
The LEM has an industrial temp range. It has to be placed externally on the DC-BUS in the -40 to 85C zone.
You managed to save one Melexis in one of the early versions of your board? That will do.This controller only needs one.:)
Version 1 is getting close.
The external amp senosor board has some beauty to it because it has only 10 parts.
That is a huge reduction in cost when compared to the KIWI project I considered earlier.
It is possible to recycle a FDU MELEXIS amp sensor.
Discussion Starter · #18 ·
Do you mean the Melexis? It is basically a bare sensor without the toroid. And it has to be programmed with special equipment. Not a great choice for a DIY project.
It does have the temp range and reliability grade for application in a -40 to 125C automotive environment. I.e. inside the drive unit.
O BTW, @Jackbauer: how is your ESP WIFI holding up on version 6(?) of your board in Romania with the winter coming? Looks like a commercial grade product.
Discussion Starter · #19 ·
@Tomdb: thanks for the feedback.
There are replacement parts for the MELEXIS that do not need programming.
Inexpensive parts (US$1 .. 3) with no export restrictions. Specifications meet the requirements for this controller.
Discussion Starter · #20 ·
This a keepalive post.
GOAL: A SET OF CANBUS BOARDS FOR A BASIC, INEXPENSIVE (EASY TO APPLY, NO "FULL FEATURES") ACIM CONVERSION.
HARDWARE
Parts count has been brought down by 4.
There are about half a dozen diagnostic parts (test pins/headers/leds) in the current board design.
One uC handles the generation of PWM AC (critical timing, high CPU utilization),
The other does the slow bits (temperature sensors, throttle conversion, ....)
SOFTWARE
There is serious breadboarding going on in the background.
Programming isn't time consuming, because there are no extra features and the uC internal hardware bits match the tasks.
Testing it on real hardware is. uCs are soldered on off-the-shelf $3 PCBs in the breadboarding stage.
There's no hurry: still no low cost, intrinsicly safe, high energy density batteries out there.
1 - 20 of 31 Posts
