Hello! So I am very new to EV cars and I've been doing a lot of reading. I'm probably a long way off from doing any projects but I'm super intrigued by all of this.
I'll get right to my question. Is it at all possible to put together a compact battery pack that can deliver anywhere from 140s to 180s volts have enough power to drive a Warp 9 or similar to 150ish lbs of torque and push RPMs to to 5,000 rpm.
Range would not need to be much. 10 miles would be enough for me.
I'm musing about the feasibility of adding a rear differential from a Golf R to my GTI and hooking it up to an electric motor. If I could get 10 miles range I'd be able to do the bulk of my local driving on electric power and maybe even run gas and electric simultaneously for an extra 150 lbs torque/100 HP to my existing engine.
whats the smallest battery setup that could support 800 to 1000 amps?
Thanks! I hope this is not the most stupid and ignorant question ever asked here.
