1 - 5 of 5 Posts
Controller and motor were parts of my Quantya electric motorbyke:
http://www.evalbum.com/4995
They are in perfect use conditions, motor's brushes are as new yet.
Controller is Alltrax AXE4844 Motor 400 Amp 24-48 Volt DC
Motor is Motor LEM200-127 LEMCO 48 VDC
I ask 270 euro for controller and 900 euro for motor.
The price for both is 1100 euro.
Controller and motor are located in Italy, but I can ship world wide.
Buyer pays for shipping costs.
These are links for viewing new items prices and features:
http://www.cloudelectric.com/product-p/mo-lem200-d127.htm
http://www.cloudelectric.com/product-p/co-axe4844.htm
ALLTRAX AXE 4844:
Programmable via RS232 comm port using PC or Laptop
Integrated anodized heat-sink with multi bolt pattern for flexibility
Fully encapsulated epoxy fill - environmentally rugged design
Advanced MOSFET power transistor design for excellent efficiency
and power transfer
1/2 Speed reverse option and "Plug Brake" options available
Type: DC "SERIES WOUND" motor controller
Under-voltage cutback: adjustable
16-30 VDC, preset to 12 volts under your battery pack voltage
Over-voltage shutdown: adjustable
30-60 VDC (48V models) (60VDC MAX)
Operating Frequency: 18kHz
Control voltage range; Key, Throttle and Reverse inputs:
Reverse Horn Output: 50mA sink max
Standby Current (Powered Up): < 35mA
Throttle Input:
ITS (inductive)
Resistive 0-5K ohm (+/-10%)
5K-0 ohm (+/-10%)
0-5Volt
6-10Volt
Operating Temperature: -25C to 75C, 95C shutdown
Adjustable via Controller Pro software:
Throttle acceleration / deceleration rate and map profile
Armature current limit
Brake current limit
Under / Over-voltage shutdown
Half Speed Reverse
High Pedal Disable
Plug Brake
LMC MOTOR LEM 200 48 VOLT 60 RPM
48 Rated Volts
215 Amp Rated Current
8.55 kW Rated Power
16.08 kW Peak Power
54 Rpm/V Speed Constant
88% Peak Efficiency
For applications involving long periods of running without maintenance the normal running current should not exceed 60% of the "maximum continuous" figure for the relevant voltage. This also applies where full-load operation in both directions is needed, unless a device is fitted to move the brush holder to the optimum position in each direction
Advantages Applications
High Efficiency
(Reduced Power Consumption) Scooters
Longer Battery Life Motorboats/Saildrives
Simple Control Lightweight Electric Cars
Light Weight Design Golf Cars
Power to Weight Ratio Go-Karts
Pancake Design Floor Sweepers
High Torque at Low Speed Grass Cutters
Pumps
Welding Generators
For more Details on this Motor please visit the Lynch Motor Company
1 - 5 of 5 Posts
