Forgot to add, if you want to know more about us, you can check out our website at modularexchange.com or like us on Facebook (M-BEAM) or follow on Twitter (MBEAMX).
Hi M-,Forgot to add, if you want to know more about us, you can check out our website at modularexchange.com
San Diego, CA to Charleston, SC is 2461 miles. At 100 miles per battery, you need 25 batteries strategically placed along the way. A conservative estimate is $10,000 per battery. That is a quarter million dollar battery budget, at minimum.....We are planning a trip across the country to prove out this concept and are hoping to set a world record for fastest crossing in an EV: 60 hours....
Yeah we have looked into off the shelf batteries for this, but what we really are exercising is the battery management technology. Our batteries measure each cell individually and monitor and balance on the go actively. If we were to buy a OTS battery, that'd be a lot of wires we'd have to hook up. However, we are able to integrate the cells with our circuit boards, giving it a really clean package. I'll be putting some new photos up on our Twitter of the battery boxes if you want to take a peek (username = MBEAMX).Your battery module spec is 1.6 kWh which is close to the EnerDel module. Have you considered using it?
That's true. However, we thought of a bit of a different way to approach this. Instead of having to sink 250K into batteries, we will be following in a truck that will be recharging the batteries as we go. We will be have 18 battery modules in our car at one time, so another 22 will be charging (4 back ups) as we go (we will be able to recharge faster than we discharge). This will effectively simulate having battery pit stops along the way, while costing a fraction of that quarter million. We know that actual implementation of exchange stations one day is a big task, but we really just want to prove the feasibility of the modular technology and the exchange mechanism.San Diego, CA to Charleston, SC is 2461 miles. At 100 miles per battery, you need 25 batteries strategically placed along the way. A conservative estimate is $10,000 per battery. That is a quarter million dollar battery budget, at minimum.
Sorry. Can't go there. Please post here.if you want to take a peek (username = MBEAMX).
I thought about that but figured you wouldn't go that route due to the comments sure to follow about all the fuel burned by the chase truck and generator. Kinda like a HEV split between 2 vehicles. Still making stops at the gas stations. Best case for press sake would be to have all the batteries charged from renewables (wind, solar) beforehand.we will be following in a truck that will be recharging the batteries as we go.
Thanks! Yes correct, we have 18 modules in parallel in the car. The Warp 9 motor is air cooled and is connected to the transmission. The controller we use is water cooled.Interesting project... so you are using 18 of these modules in parallel or did I misunderstand the specs? Are you using the transmission and is the motor force-cooled? When is the trip scheduled? This project should get a lot of attention.
Here is a pic of our proto battery module: https://pbs.twimg.com/media/BZpIzjjCEAAhf8Q.jpg:largePlease post here.
I agree, it would be best to say that the energy came from renewables. However, we don't have a huge budget for this kind of thing, so we will have to make do with this strategy for now. We anticipate those comments, but in reality this is not much different than the fossil fuels being burned at power plants that power electric car charging stations. I don't think it can really be compared to an HEV, but that I guess depends on the frame of reference. We are going to plan it out so that the gas stop is also a battery swap stop, so it doesn't eat into the time too much.I thought about that but figured you wouldn't go that route due to the comments sure to follow about all the fuel burned by the chase truck and generator. Kinda like a HEV split between 2 vehicles. Still making stops at the gas stations. Best case for press sake would be to have all the batteries charged from renewables (wind, solar) beforehand.
Before I make my comments and questions I want to applaud your effort.We anticipate those comments, but in reality this is not much different than the fossil fuels being burned at power plants that power electric car charging stations.
pouch cell packs ?Here is a pic of our proto battery module: https://pbs.twimg.com/media/BZpIzjjCEAAhf8Q.jpg:large
Thanks Doug!Before I make my comments and questions I want to applaud your effort.
I agree, gas engines are not as efficient as power plants. However, we are trying to showcase the feasibility of the modular technology, anticipating that, in the future, energy in the battery will come from renewable sources. We are making do with the resources available to us. We plan on using generators to charge while on the road.There is a huge difference between burning gasoline or diesel to spin a generator and the output of a power plant...What is the plan to generate the electricity to recharge the battery?
That was a concern of our initially (we thought about water jacketing it). But we looked at the draw of the motor, operating continuously at 70 mph (which is our estimated average speed for the trip), and it only takes about 15 hp to maintain that speed. The motor should operate just fine under those conditions.A WarP 9 motor operating continuously for 60 hours at highway speeds may be pushing it even with additional forced air cooling. I suggest you install some temp sensors and keep a close eye on it.
The boxes are designed so that they just slide in and out of the battery rack. We haven't built the full rack up yet, but we anticipate it taking about 10 sec to switch a module with a new one. Having two people exchanging modules, it would be about 1.5 min to switch out all 18.How long does it take to swap a module? How long for all 18 of them?
It is all about the the size of your charging station and the effect on the batteries. Let's say you have a Tesla Model S 85 kWh pack in a car and, assuming their max of 3.2 miles per kWh, you would still need supercharging stations (100kW) to charge up the full range in about 50 min. In order to get these times down to a more "palpable" charge time for the public, you would need much higher wattage charging stations. It is hard to imagine having charge stations that are higher that 1/2 a MW. Plus you have to take into account the effects of battery degradation due to the fast charging of batteries. I agree that it seems like the future of EVs is going down the path of fast charge, but I think that we are going down the wrong path with some severe limitations in the future, and that modular batteries would alleviate most of those problems. Heck, with modular, you could even fast charge if you wanted to or swap them out on long journeys!Battery swaps when the battery can be charged this fast are unlikely to ever catch on.
And yeah, our biggest obstacle in regards to the vehicle is the auto industry. They are slow to accept any slight change to their vehicle structure, so asking for common battery technology and changes to their vehicles is going to be hard. But it's got to start somewhere and now is the time.Automakers have always had a terrible case of "Not invented here syndrome."
pouch cell packs ?/QUOTE]
We decided to use pouch cell packs because we could have a better energy density to weight ratio, using custom enclosures. Each pouch cell is 10.67 Ah made of Lithium Iron Phostphate, and has a very low impedance. They were the best we could get on the market for the price.
