The concepts of magnetics and electromagnetism are fundamental to the understanding of motors, transformers, and buck or boost converters. I am trying to get a better handle on these concepts, and explain how such things work in a way that does not involve very much higher math. There are some resources that I found which may help anyone who wants to design, improve upon, or troubleshoot such items as chargers, controllers, transformers, and motors.
http://www.smps.us/magnetics.html
This has a pretty good explanation of transformers and inductors, particularly as used in switching power supplies (SMPS). It is important to note that a transformer is designed to transfer energy from the input to the output, while an inductor stores energy over a period of time and then releases it. Either device may be used to produce higher voltage or higher current, but the transformer uses winding ratios to change the voltage, and an inductor uses the change of the magnetic field to accomplish this.
http://www.epcos.com/blob/519704/download/2/ferrites-and-accessories-data-book-130501.pdf
This catalog has a very good and highly detailed description of various types of ferrite and their preferred application, which includes power transformers, resonant inductors, noise attenuation, and filters. It also explains how a gap in the magnetic circuit is used to store energy while having no gap is used to transfer energy.
http://www.poweresim.com/Xformer/Select_Application_Front_Page.jsp
This is an on-line calculator which allows you to choose among many common topologies, and determine the proper core and windings for a working design.
http://www.animations.physics.unsw.edu.au/jw/electricmotors.html
This is a good reference with animations, showing how various types of motors and generators work. There is also information on transformers, speakers, and other magnetic devices.
I'll continue this discussion in further posts. Feel free to add questions, comments, corrections, and additional information.
