1 - 11 of 11 Posts
Used, in good condition. Located in SF Bay Area, California.
Input Current Range: 0.2 to 30A AC
Output Current Range: 0 to 40A DC
Height: 5.5 inches
Width: 9.0 inches
Length: 13.0 inches
Weight: 17.2 lbs
Mounting: 4 holes, 5/16" each
Charge Algorithm: Constant Current/Constant Voltage
Output Voltage Range: 12-360 volts
Input Voltage Range: 60-240 volts, 40-80 Hz
Efficiency: 88% to 96% percent (varies by voltage)
Power Factor: .92 to .9997
Connection In: #10-3 Cable w/Plug
Connection Out: #8-3 Cable w/Plug
Input Protection: 30A 240V Breaker
Output Protection: 50A 450V Fuse
Isolated: No, negative input and output are connected
Display: Red LCD 3 digit, Amps drawn
Preset Cutoff Voltage: Yes
Adjustable Cutoff Voltage: Yes, via trim pot (20v/turn)
Adjustable Cutoff Time: Yes, adjustable 0-150 mins
Adjustable Current: Yes, via panel mount rotary knob
Thermal Cutoff Point: 170º F
Thermal Cooling: Thermostat controlled, variable speed fan
Reverse Polarity Protection: Yes
Warranty Period: One year, or 1000 hours (More Info Below)
120197
120198
Discussion Starter · #7 ·
I opened the unit up today to see if I could switch out the NEMA 14-30 for a 14-50 so I got more pictures of the internals. They were too clean, neat and fixed to easily switch out the cord so ordered an adapter instead.
Looking for offers!
120856
120857
120858
120859
1 - 11 of 11 Posts
