I just picked up a dnepnr motorcycle with sidecar
It's about 650 lbs it has a Motenergy 1003 I am running it at 84 volts through a 7243 axe controller
Motor seems to be getting hot and throttle response is jumpy. I checked the pot and seems to be smooth. Is this motor enough for the weight of this ? It is running direct shaft drive to differential that is reportedly 4.3 to 1
I noticed that they have an improved brush set-up with better brush material Would that be worth it ?
I have a Zilla 1k that I will replace the controller with eventually. I was planning on setting the Zilla to match the specs of the motor voltage and amperage wise. That should work????
