1 - 13 of 13 Posts
Hello,
Wanted to share what we been working for the past year or two and gather some more feedback about. (I already got some see below)
We decided after Hurricane Maria in Puerto Rico to allow our aircraft BMS we designed to be used for diy powerwalls and HV conversion packs.
Here is a link to the post with the specs.
https://medium.com/@annerjb/battery-management-system-and-shunt-wip-specs-3fdd12e576b4
It should also work with 24v and 48v packs using 6s and 12s packs same way Tesla does it.
TL;DR:
In terms of pricing and delivery this is our price targets:
BMS(master board) $120 USD
BMB(slave board) $98 USD each (up to 6 cells each 24v ) some sort of volume discount if more than one is needed. (includes thermistors)
Shunt $100 USD
Any feedback on it? Especially regarding connectivity and outputs?
Premium Member
If I read the specs correctly, the slave boards are supplied independently by 12V power. I like this. No parasitic draw for individual cells for the BMS slaves. I don't like the "18V to 75V" (DC?) input for the BMS master board, though, for an automotive application. If I were use this system, I'd have to get a DC-DC converter just for the BMS master. What current draw will the master board have?
Haven't calculated current draw for bms yet (right now it's as a developer kit/collection of small boards).
We made it have a wide VIN so it would work for anything going from 12v (same power source as BMB, to 48v packs)
We do have another board that is a DC-DC from 425V DC to 24V (and/or 12V)
This was made for the aircraft we are building but we weren't sure if there was any demand for them. If there are enough people interested in them we can make a production run of them.
That way you can power the BMS directly from the battery pack and the BMB's.
Is this something that's useful right now they are 600 watts DC-DC (two DC-DC one intermediate to 65v or 70v If I recall correctly) and a low voltage one from HVDC to 24v or 12v.
Premium Member
I'm a little confused - the specs on the page say "18V to 75V". If it can indeed operate as low as 12V then I'm happier.
Regarding the slave boards - can they bridge a service disconnect gap? In other words, if I have a service disconnect in the middle of a group of 6 cells, will there be any problem when it is disconnected? There of course would be no pack charge or discharge when the pack is broken so no need to manage the system during disconnect.
Also, how long can the battery terminal leads be? What kind of wire will you recommend? Do you do anything for de-noising of the voltage sensors?
"I'm a little confused - the specs on the page say "18V to 75V". If it can indeed operate as low as 12V then I'm happier.
There will be a direct connector for a 12V regulated power and a separate raw 18V to 75V voltage connector.
Preferably a direct connection from the battery.
Regarding the slave boards - can they bridge a service disconnect gap? In other words, if I have a service disconnect in the middle of a group of 6 cells, will there be any problem when it is disconnected? There, of course, would be no pack charge or discharge when the pack is broken so no need to manage the system during disconnect.
If that happens, you will get an open circuit fault from the balancer/slave board.
If catastrophic failure (IE, short circuit), the balancer will cease to operate because is self-powered from a 6 cell group. This will show up as a missing slave board.
Depending on the balancing current, we are shooting from 50mA to 200mA (Depending on the balancing shunt inside the slave board). Anything from 30 to 24 AWG should be sufficient, of course, if you use a longer wire there will be more heat and the balancing current won't be as effective as it should be. I would say no longer than a foot.
As for de-noising the voltage sensor, there is a low pass filter inside the board helping with this aspect. Inside the balancer chip, there is a digital filter for further smoothing
We been working on making a sub 150$ 16 cell BMS.
Was wondering what sort of thermistor mounting setup is more common?
Right now we have the thermistor on a small PCB with a JST connector.
Are there any feedback or preferences for different ways to mount the sensors?
We took your feedback and Facebook Group about providing instead a single board that could balance and monitor more than 6 Cells.
We are still in development of this one so feel free to provide feedback regarding connectors. Same specs as before only difference are now you can balance and monitor up to 16 Cells.
We are aiming for a price of $175 USD
What do you guys think?
Since i am looking at BMS for a 180V 48 taps - each with 4 cells in parallel. I am interested but a little worried about your dissipation amperage due to the 4s cells
Discussion Starter · #9 ·
the number of cells in parallel won't have an effect on the heat generated since the system will balance between series. The important part is how many cells you have connected to a single board 6 or 16.
If you have 16 cells, the balancing algorithm to maximize the lifespan of cells won't balance adjacent cells. this will help in not generating an excessive amount of heat. but yes we took it into account on the design amount of watts generated by balancing and board design.
One thing to keep in mind right now we have 140milliamps of balancing per cell. This should be sufficient unless your pack per cell has a lot of kwh/ah.
Since the cells are balanced before soldering in the bus bar and are carefully maintained all the time in balance.
Please go for a dedicated control board, for reliability, etc.
look at competitors, Lithium Balance sells there 8s CMU's for €60 a piece... BMU about €250.
could be hard to compete with that, where could you save on costs?
And please do a -lot- of testing before selling, not good to damage a pack...or start a fire... because of a bug...
There is a dedicated control board which is the Master BMS board. The slave board picture above only does balancing when commanded by uart or can bus.
Possibly when detected if we add an algorithm to measure voltage rising across cells. But this is not expected on the first version of the software.
Primary reason is that the Shunt/Current sensor needs to communicate to a master board to accurate calculated SOC of your whole pack.
We been running this boards since 2016 for our aircraft conversion battery packs. We also intend to run them thru thermal chambers when we have a final design to make sure everything is running well. We have been designing software and hardware for the past 10 years for the military and server industry at our day jobs.
Discussion Starter · #13 ·
we added more bleed resistors and upgraded the connector to screw terminals to handle higher current.
Still WIP
1 - 13 of 13 Posts
