I installed a new Masterflux AC unit and controller in my VW conversion and I'm having problems.
1999.5 VW Golf, 208V Thundersky 90ah, Warp 9, Soliton 1, Meanwell 600w DC2DC, Elithion BMS.
Compressor was easy to install with custom hoses. Finished install in late August, cools great as long as the car is sitting still. The controller converts the pack voltage directly to the DC powered compressor. Unit is proper voltage size compressor and controller.
The problem is when the car accelerates the controller cuts off. As soon as I take my foot off the pedal, the unit starts right back up.
I have added the recommended diode to prevent controller interference. We have put a scope on the power lines and we are not seeing big swings in the voltage. Controller has built in safety protocols that shuts down the system when there are problems, like over/under voltage. We are not seeing voltage sags.
I can speed up the motor to just 500RPM and the compressor will start bucking and surging and then shut down.
I have moved the controller away from the motor and controller to see if it was EMI, but that did not fix the problem.
We made up a low pass filter with capacitors and inductors, no noticeable change.
Isolated the 12V relay with an external power supply, no change.
I have connected to the serial port with Putty to monitor the voltage, but the recommended setting only show gibberish. I have tried every other setting I could find and still can't see the output.
I'm thinking there is something I'm overlooking, anybody with experience out there?
Thanks
Thanks
