can you please share?
It think that's probably true of all of these pumps for electro-hydraulic steering. The trick is that in most of the more recent designs the integrated controller (which handles idling when hydraulic power is not needed) expects information by CAN for steering angle and/or road speed, which it needs to choose a boost level. A pump which doesn't care about the CAN connection (such as that one from the Mini) avoids that problem.... I used the electrohydraulic power steering pump from a Mini Cooper S in my Mustang. Since it has an integrated controller, you basically wire it to power, and it will run itself - including "idling" with low RPM when going straight...
