If I understand that photos correctly,![]()
this conversion is 4WD using Leaf drive units at both front and rear, using the original W163 suspension at both ends. It looks like a very tidy job.
Both seeing this, I did not realize that the W163 used torsion bars for front springs
yes, good job
Thanks for the question ., there are a lot of conversion projects, in mlev there are two em61 motor reducers inverter with zeo and pdm azeo ., tidy, selector, abs, ecp by stokQuestions:
Which motor/inverters did you end up using? The EM61 or EM57. From the pictures I assume EM61 (gen1)
It looks like you used modified half shafts (CV) but in the picture I see drive flanges, confusing
Did you use the gen2 PDM?
You can use the buttons below the text boxHow can I add more photos and videos here?
I am now finishing my Saab 93 cabrio and a Daihatsu Rocky for a friend. I would love to do a conversion with this M series, it looks very tidy. Also they are relatively cheap here in NLThanks for the question ., there are a lot of conversion projects, in mlev there are two em61 motor reducers inverter with zeo and pdm azeo ., tidy, selector, abs, ecp by stok
