1 - 1 of 1 Posts
Discussion Starter #1
Here are few simple methods you can follow to avoid car battery failure and also keep your battery juiced up.
  • Switch off the lights and unplug the accessories when not in use. Just leaving one light on overnight is enough to make your battery die.
  • Conserve energy. Don’t take constant short trips. Your battery requires a minimum time to charge itself fully. Frequent short trips will result in inconsistent charge levels.
  • Maintenance is the key to battery health. Always have a professional inspect your electrical systems.
  • Parking your car in cooler locations during hot climates can help. Test your batteries for car before summer so that you are prepared.
  • Keep your battery terminals clean and free of corrosion
1 - 1 of 1 Posts
