1 - 4 of 4 Posts
Hey Guys,
I'm in the process of converting an MGB GT to fully electric.
The basic plan is a netgain warp 9, 60*100AH TS batteries, and a Soliton Jr.
I'm documenting the process here:
http://electricmg.wordpress.com/
So far I've purchased the motor and am in the process of machining a coupling to connect the motor to the flywheel (I'm keeping the original gearbox).
I am wondering what kind of range I am expecting? And how important is weight to range? I can imagine it effects the acceleration (and so requires more energy there), but once at a steady speed the mass of the vehicle shouldn't much effect the range (I think)
Cheers
Range would depend on the speed you are generally travelling at.
But for a small car you can estimate your w/mile at 200-250. 3.2 * 60 * 100 = 19.2 kw.
Which gives you 76.8 miles at 250 w/mile, or at 80% DOD ~60 miles which is ~100 km.
At 170v @ 500 amps you'd make 85 kw (including voltage sag).
1 - 4 of 4 Posts
