What are your performance goals? It's complicated, there are no guides, and you should expect the cost of parts to look like $5k if you want highway speeds and 50+ miles of range.
The cheapest way in seems to be buying a used Nissan Leaf and then taking it apart instead of driving it around. You can get by with spending less, but range and power will be significantly reduced.
Sniff around here some. Cost and effort depends heavily on what you want to end up driving.
