Hi Frank,
did you fix your issue with the charger?
My Fiorino didn't charge, please see below.
thx
Christian
Fiat Fiorino/ Micro Vett, Construction year: 2009 / 2010
Battery Charger: Zivan NG9
Hi all,
my Fiorino didn’t charge.
If I plug in the power socket I hear a noise from the fans.
But they didn’t start the charging process.
Does anyone have any idea where I should start debugging?
Is the charger connected to the BMS?
Thanks in advanced.
Christian
---- Update --- 2019-09 - 04 ----
I have a Zivan NG9 Charger customized for a Micro-Vett Fiat Fionino (2011) which has a "line error" after switching on.
Details see YouTube Video https://youtu.be/ZewaRwDHBaw
I have also attached some pictures.
I have checked the supply lines and fuses in the device, they are OK!
--- Update --- 20191204 -----------
I send the device for repair to the German distributor:
ATECH GmbH, www.atech-antriebstechnik.de
I also contact Zivan in Italy directly but the repair haveto be handle from a local distributor.
Activities performed:
Clean and check charger, repair defective power supply,
Re-adjust and seal the device, perform a function test.
Cost: 482 € inkl. Cost estimation and shipping
Turnaround time 6 weeks
thx
Christian
Hi all,
Thanks in advanced.
Christian
