Hey everyone I have a set goal in mind to convert my car into a Hybrid using an electric motor that will attach to the crankshaft pulley or at least to one of the pulleys on the drive belt but some of the questions i have are: What kind of motor should I look for ? (i read somewhere that the torque measurments for electric motors are not the same as car engines) also is it better to convert the electricity from the alternator to (a higher voltage if it would be better to use such a motor) 48v so to charge a 48v battery pack or would it be more efficient to use a secondary car battery at 12v and then convert it to higher voltage or to just use a 12v motor
P.S I am looking to mainly increase the torque of the car at the lower rpm range as all NA gasoline cars lack low end torque but also every other bonus that i would get out of it is welcome.
