Just an alternate solution to those mentioned above. I'm using an Odyssey PC625 AGM to power all 12V, but a Chennic DC->DC set at 14.5V to charge the Odyssey (recommended charge voltage). While the Odyssey is only about 16 AH in capacity, this setup pretty much means the Chennic does most of the work while the AGM acts like a buffer.
I've got the converter wired to a secondary contactor to come on when the ignition is switched on, but the 12V AGM is always in the 12v circuit (like the original 12V battery was)... though it's on a small cutout in case I want to kill all power everywhere.
I prefer the "battery-buffer" for its ability to act as a backup power source, as well. Say something goes wrong with the DC->DC or main pack, the AGM is there to provide headlights, hazard lights, brake pump, etc... for at least a little while.
Now, I haven't hooked up the Chennic yet, though I have it with me in CA, but I have run the beast off the AGM alone, and aside from the voltage load on the small battery dipping below the min-voltage threshold of the Soliton-1 occasionally, it was fine. When I get back to the southwest in May I'll pop in the Chennic.
I'll see how it goes, but the Chennic should keep the AGM charged while driving. It outputs 400W and I'm nowhere near pulling that much power. If it isn't enough, I'll consider not switching the DC->DC with ignition and just have it on all the time.
The AGM solution was about $110, but it's light and small.
