1 - 9 of 9 Posts
Discussion Starter #1
Is there a Molex 4 pin to Ampseal 35 pin adapter?
For using either a Curtis 1311 or 1313 programmer with a 1238 motor controller?
I have no wiring harness at the moment, and though I would like to rectify this situation as soon as possible, I would also like to be able to connect my controller programmer to the controller to see if I need to do future upgrades (like getting the software reflashed, if it doesn't have the right software installed) without having to send the controller away to find this out.
If it is not available, can one be made?
Thank you in advance to anyone with information.
Easy to make, just get the two connectors, and pins and make one.
Have to power up the controller through B- and KSI at least.
Discussion Starter #3
Let's assume that it's not something that I would prefer to make myself, would you know where I could buy one?
Discussion Starter #4
What is the lowest voltage that I could power my controller on, in order to run the programmer?
Which 1238 is it? 12V would be enough to program it.
Do you need a full harness? or just a means to program?
Email me and I can assist with getting you that.
Where'd you get the 1238? Is it matched with a motor.
1 - 9 of 9 Posts
