Hi bumb,I'm sick and tired of the limits kicking in on these controllers when I'm in the middle of a race.
Why would you think these two attributes would go hand in hand?What's cheapest and most powerful controller for racing??
You are correct on the current, however the power doesn't exactly work like that, you will not get 376hp from 0 to 5k rpm.eVnetics Soliton-1 or the Netgain Controls Warp Controller are similar in price and power and are currently supported controlers, while the Zilla is hibernating (again)...
The Soliton-1 can put out 1000A whenever you need it..if you go max voltage with your battery pack, 320V, Voltage sag @ 1000A will take you down to 280V, so 280kw = 376hp (@ 0-rpm all the way up to 5000rpm)
I'm sick and tired of the limits kicking in on these controllers when I'm in the middle of a race. What's cheapest and most powerful controller for racing????
Take care Bowser......so 280kw = 376hp (@ 0-rpm all the way up to 5000rpm)
If that's so, how about a few of them? You can divide the pack in a couple of stages with a lower voltage to start and then applying a higher potential after you break inertia. You might be able to wire some for a 12V slow parking job.The contactor sounds like the best idea yet!
A knife switch.What's cheapest and most powerful controller for racing????
