I agree. Have you planned a vehicle? I am planning on a reverse hybrid trike using a small motorcycle engine and rear wheel with the front wheels driven electrically. I will be using the sub frame from a small disposable econbox for the front frame.
Here's why not:
1. I typically drive more than 50 miles, and frequently quite a bit more than that
daily?
2. Charging at work is not an option
why not?
3. Charging virtually ANYWHERE other than home is not an option
understandable just because most people are not anywhere other than work fr long enough.
4. I'd rather not have to buy another vehicle just to travel outside the EV range
then rent one when needed? neighborhood share?
5. Biodiesel is a lot more trouble than I'm willing to go to. I'm looking to save money.
trouble? what if cities have biodiesel growing at waste treatment plants, and sold at usual gas stations?
6. LiOn is really expensive compared to deep-cycle lead acids, and for this theoretical vehicle we don't need very many batteries. Batteries can be upgraded later when they come down in price.
Li batteries are ALREADY less expensive than lead if you look at cost over life miles. They cost maybe 2.5x, but last 5x... easy math.
Hi All,
After having followed DIY and commercial hybrid and EV progress for over a decade, I finally came to the conclusion (as have others) that the most practical solution given the current level of ICE and battery technology is a vehicle with:
1. An electric motor and battery pack sufficient to get it up to highway speed quickly, with a range of around 25 miles
and
2. An ICE with around 30HP, matched in gearing to most efficiently keep the keep the car at highway speed (with enough extra HP left over to run all accessories and re-charge the batteries).
Why this configuration? It's the most cost effective from a $/mile standpoint. Electric motors are great for acceleration but currently have power storage issues. ICE's are great for steady RPM power applications and have great energy storage, but are horribly inefficient when used to accelerate. Solution: Use each for it's best purpose.
My understanding is the average passenger car only needs 20hp to overcome wind resistance at highway speed. 30hp leaves enough to run all accessories and recharge the battery pack (under all but I expect would be considered 'race conditions').
A 25 mile EV only range is enough for the majority of around-town driving (to the store and back).
This configuration would keep the vehicle's weight close to the original curb weight, so handling would be the same and suspension components won't need augmenting.
As technology becomes available (better batteries, motors, etc.) they can be swapped in, and the vehicle will be easily customizable for greater performance vs. efficiency, EV range, etc.
I personally think this is likely to be worth doing when gas hits $8.00 a gallon, but I'm an optimist.
I also think that the automakers will eventually start building these (they have to have come to the same conclusion years ago), but again, I'm an optimist.
All input is welcome.
TIA,
Dave
You make a great deal of sense, and perhaps the path of least resistance/cost effectiveness is to just buy a hybrid and hack it. I'm just not a fan of trying to fix things that have intentionally been made overly complex (all cars eventually break, and fixing them is a major cost of driving).I've said for years that a plug-in hybrid is the next step after hybrid,
before we can get to all-electric for a significant percentage of cars on the road (or new ones sold). Remember that while millions of hybrids sold, they are still a tiny percentage of cars on the road or even new sold.
But you really must distinguish between what car makers will make,
and what YOU can make or build for yourself or 10-1000 others.
A hybrid is more complex mechanically for a DIY. Not sure it is really worth the trouble or effort, this really is a hobby for 99% of us right? A pure EV is much easier to build, if not the most "practical" because of range. But I am building a hybrid currently, as my hobby is doing what is hard, not easy.
Used small motors are cheap, it is batteries that are expensive for DIY.
As for controls, my simple plan is to power the electric motor and gas motor in parallel, basically make the ICE work less hard and thus get much better MPG.
I'm with ya Dave but my question is why not use the electric motor as the drive mechanism and have the ICE handle charging duties alone? It seems to me that would simplify the issues. The motor could be tailored to the type of driving that you need while the ICE could be chosen solely on charging efficiency.Hi All,
and
TIA,
Dave
That's how the Chevy Volt works, but the problem is efficiency. When you burn fuel to turn to electricity to store in a battery and discharge in a motor you lose energy to heat at every step of conversion.I'm with ya Dave but my question is why not use the electric motor as the drive mechanism and have the ICE handle charging duties alone? It seems to me that would simplify the issues. The motor could be tailored to the type of driving that you need while the ICE could be chosen solely on charging efficiency.
Just a thought.
