This weekend, I attempted to run my A/C compressor from a treadmill motor. I studied the compressor curves and came to the conclusion that it would pull under 3HP so I thought a 3.8 CHP treadmill motor might work. I guess I should have believed the folks that said treadmill motors are not correctly rated. Everything looked great until I started to charge the system with refrigerant and engaged the compressor clutch. I quickly turned the motor into a boat anchor. I am back to the drawing board.
I need to have a smaller footprint motor but most of the small motors in the EV world are rated for under 50V. I’d love to use a TEFC AC motor, however, I can’t figure out a good way to drive it from my DC pack. Most common bus AC drives need higher voltage. Has anyone successfully utilized a 3-5HP AC motor to drive accessories (short of building own controller)? Any other thoughts for driving the compressor? I have a dual shaft main motor but it looks like a nightmare to try and mount my compressor in a manner that would allow belting to the main drive. I am only going to do that as a last resort.
