Yeah, that looks like the floor burnisher part number. Based on the pics it seems to be a Motenergy motor, must be OEMed.Part #1200569
closet thing to a model number on the motor
1.5kW at 24V is 62.5A. If you double the voltage, you will get 3kW continuous - seems like still quite far from your target.Any opinions on this motor? Drive motor from 6000lb crown pallet jack. I'd like to run it at 48v but I'm not sure it's enough power.
I don't know if it requires it. You probably would get away with slight downrating, but how much does a "road going car" take ? I googled just now a Toyota Corolla - 139 to 169 HP, so over 10 times more than what you're looking at.Ya that's what I was thinking. Just seems crazy that my little tractor would require the same size motor as a road going car.
I want to say it's 10-11", but I can't get to it at the moment to measure. NOT SMALL for sure. Anyway, my point was that those big lift motors can deliver quite a bit of power under increased voltages given their current ratings.How big is that motor?
Some other folks may have a better answer to that, but personally I wouldn't hesitate to ramp it to 200-300A, especially if you add/use a temp sensor and cut back on overheating.I have this one available too but it's almost 11" in diameter. Any way to know what kind of juice I could run through this?
Are you not concerned about the fact that it is rated for intermittent duty?View attachment 127143
That's a Peerless-Winsmith I pulled out of a boom lift. Extremely heavy, and note it's only 7HP while being rated for intermittent duty. View attachment 127146
I was showing you that motor just for the scale reference. Series wound motors just happen to be big and heavy while delivering little power compared to PM motors whether AC or DC. This specific motor I replaced with AC-23 in that machine, I don't have any upcoming projects for it.Are you not concerned about the fact that it is rated for intermittent duty?
Did you replace it because it was unreliable or not working well?I was showing you that motor just for the scale reference. Series wound motors just happen to be big and heavy while delivering little power compared to PM motors whether AC or DC. This specific motor I replaced with AC-23 in that machine, I don't have any upcoming projects for it.
I don't know either. I'm just going by the fact that the original engine was 12hp to 18hp depending on the model. That would be somewhere around 9 to 13kw. I know that electric motors provide more low end torque but I don't know how much different it would be.I don't understand why you need so much power to tow a roller. Is it round or rectangular? Towing at 30MPH?
More than 4 or 5 kW on a reduction chain/belt will just spin the tires.
