Have any of you guys used a snubber diode or a capacitor across the motor to reduce noise? I connected an o'scope across my 12V supply, and if press the accelerator I have noise all over the place until I let off. I feel like I've separated the HV and LV lines sufficiently. Maybe it's carbon dust creating a path? Also, I made a tachometer using a micro controller that quit working correctly when I switched from my Netgain controller to a Synkromotive. Could it be the controller's fault?
Sent from my SM-G920V using Tapatalk
