1 - 3 of 3 Posts
How much horsepower do the 12v forklift motors that I see all over eBay put out? (Eaton, Baker, etc..)
I'm having a hard time finding the information, for the application that I'm looking at using one for, 10hp is MORE than enough (I could make do with as little as 5 even - not using it for a car, but rather as an inboard for my sailboat to get in and out of the Marina.. sorry I know this isn't technically relevant to this community, but I thought this Forum has the same intent/spirit I have, not blow money and not fill the air with smoke)
Sent from my Pixel using Tapatalk
Hi Kar,
Forklifts rarely use 12 Volt motors. In the USA, 36 & 48 Volt systems are most common. In Europe 72 Volt systems are used. There are exceptions but 12 Volt motors are uncommon except on some pallet jacks.
http://www.diyelectriccar.com/forums/forumdisplay.php/electric-motors-37.html
I suggest you spend some time reading through the first two threads in the above sub forum.
There have been several members do EV boats. Look here: http://www.diyelectriccar.com/forums/forumdisplay.php/non-road-going-vehicles-41.html. After you read up a bit, that would be the place to start a build thread of your own.
Regards,
major
HP = KW (watts) / 746
Example :
12v x 200 amps = 2400 watts / 746 = 3.21 hp
Controller and battery choice also are a factor.
Most small motor controllers start at 24v. Check out the stuff from 4QD https://www.4qd.co.uk/ or Alltrax.
A 12v motor will probably run fine on 24v as long as you limit amperage, therefore limiting total power.
I ran a 24v hyster motor on 36v for a go-kart, the limiting factor then is how much power can you dump in for how long and avoid heat build up ;)
remember, twice as fast for half as long ;)
1 - 3 of 3 Posts
