Hi all, I'm planning out a build and am tackling the motor/controller portion. I'm a fairly technical person with lots of electronics repair experience, but no experience with motors aside from a little R/C flying. I know some basic theory and played with them in the lab in college but that's it. So I've been doing a lot of research.
I'm a little confused about motor HP ratings.
I've been doing a lot of reading and research and here is where I am stuck.
HP is HP whether it's ice or electric right?
I see a lot of guys using forklift motors, aircraft starter motors, etc.... and looking into it they are generally rated in the 1.5-5hp range. I've seen a lot of industrial motors on kijiji that look large enough to be "the right fit" for an EV, going by size and they are all in that range of HP too.
If i were to use one would the car just not perform as well as say a warp 9 or something like that?
Or would i need to get the motor rewound to be say 50-100hp or is it the voltage you put on it that ramps that up?
I've been looking and looking and it's something I'm a little confused on and I can't find a definitive answer to.
If anyone can shed some light on this I'd really appreciate it.
Cheers,
Colin.
Cheers,
Colin.
