Hi.
I finished with electric motor installation so now is everything ready for first start. 11KW AC Motor is connected to transmission and the other end of the shaft is connected to starter which is connected to vacuum pump.
As controller i'm using Simens Midimaster 40KW inverter.
I tested the motor with this controller, when the motor was outside of the car, now when it's in i have some questions regarding electric security. Controller will be connected to 3 phase AC ( for test ).
I dont know how is this in praxis but i need suggestion regarding grounding.
Question:
Do i need to make some special grounding or is it enough to connect 3 phase on the motor and controller and make the grounding directly on those two ?
Thank you in advance.
Question:
