Motorcycle with a Sidecar Conversion
4089 Views 11 Replies 6 Participants Last post by  zapyourrideguy
Similar to a few others here, I am planning a motorcycle with a sidecar conversion to an EV. I am still in the early stages and looking for a bike. I'm trying to plan out what all I will need.
So far, here are the specs I have considered:
Total vehicle weight: 1,100 lbs (fully loaded with 1-2 riders)
Desired max speed: 70 mph
Desired range: 50 miles ( I commute 25 miles each way, but my boss has said the company will provide me a way to charge it here)
Based on that, I am thinking about a 72V, 100 Ah setup. What size motor should I be looking for? The stock Urals weigh 750 lbs unloaded and have a 42 HP motor so I was thinking that I want at least 50 HP.
I would like to stay under $5k for the project. I will be doing all of the wrenching and wiring myself. I am a mechanical engineer with a lot of fabrication and machining experience. I also work with a few EEs that have offered to help once I get into more of the wiring and programming aspects.
Thanks for the help!
1 - 12 of 12 Posts
Rather considering the ICE's peak power and the motor's continuous rated output, consider your ICE's power curve.
When accelerating, your power would be lower just after a gear change and highest near your shift point, which probably isn't at redline. Look at the power output in the middle of that revband. This may give you a more realistic ballpark for your motor spec.
That's a good point. Just out of curiosity, what size motor would output about 50 HP anyway? I'll have to look and see if I can find a power curve for the Ural's 750cc. If not, I don't see a problem with having a bit more power because I know with all the batteries and all this thing will probably be HEAVY.
I have the Dnepnr with the ME 1003. I will be transitioning to an AC-30.
The little ME 1003 performs pretty well. Just a note, it may be my bike (older '83 MT-16) but I wouldn't want to go anywhere near 70 mph on it. 45 to 50 seems scary enough. The newer Ural's may be more refined machines but sidecar dynamics may be a limiting factor as far as speed.
I have an 89 mt16 dnepr and was think of going electric. Can you share how you did yours
[Edited by Mod, I think this is what he meant to do]
my Dnepr is finally in the finishing stages with AC-30 (an older version of AC-35) and 1238-6501 controller
It was direct drive and did ok, but I put in a 2:1 reduction using gates synchronous belt. It now goes as fast as I would want to go on this bike. The AC-30 motor plate states 35 hp max 10 hp continuous. its geared to go about 50mph.
Do you have any pictures of the reduction belt drive you came up with?
Hi!
I have inherited a 1994 Ural and have started the project to convert it to electric. I have access to this motor and these batteries plus this controller. These are used, but condition should be good for the price.
I am curious about many things, but for now the question is whether the gearbox can be removed. There is a reduction gear in the final drive, but my documentation doesn't contain any figures. Any ideas what that might be?
@zapyourrideguy, what is the gearing in your reduction belt drive? Indeed, it would be great to get a picture of the implementation.
Gates synchronous belt and sprockets
Here is shots It is exactly 2:1. My dnepr final drive is 4.6:1 which I believe would be similar to ural. Top speed is low 50-55 but hill climbing is really good. And bike accelerates briskly. But If the transmission fits I would tend to keep it for the flexibility.
it.
Motor vehicle Automotive tire Automotive design Automotive exterior Grille
Machine tool Gas Motor vehicle Engineering Metalworking
Motor vehicle Automotive tire Machine tool Gas Engineering
1 - 12 of 12 Posts
