My DIY Electric Hydraulic Mini Wheeled Skid Steer Loader.
1703 Views 1 Reply 2 Participants Last post by  vmaijala
Hey guys,
I just want to share a build log of my mini electric skid steer project. Here's some infos below.
Dimension:
Width: 35"
Wheel base: 28"
Height: 36"
Weight Est: 1200lbs
Motor: 4.5kw
Battery: 4.8kwh 48v 100AH
The project is currently in progress. Part 1,2,3 is available.
Part 1
Part 2
Part 3
Part 4
1 - 2 of 2 Posts
Hey guys,
Dimension:
Width: 35"
Wheel base: 28"
Height: 36"
Weight Est: 1200lbs
Motor: 4.5kw
Part 1
Part 2
Part 3
Part 4
Hi Jimmy,
Great work you have done with your mini-loader. I have a similar project, with the difference that I already have the very similar size loader with gasoline engine.
So few questions... Where did you buy that engine+pump combo (I assume it was combo?)? How did you size that? What was your budget for electronics+hydraulics?
Cheers,
Ville
1 - 2 of 2 Posts
