Neat - Oil and Water display
1848 Views 0 Replies 1 Participant Last post by  rbgrn
http://www.tech.co.uk/home-entertai...ps-oil-and-water-displays?articleid=951565664
Philips has been working on flexible displays for a while - it's even formed a subsidiary called Polymer Vision
LG Philips has filed a patent application for a new type of thin, flexible display which uses oil and water inside the pixels. Currently, the company uses OLEDs (organic light-emitting diodes) mounted on a thin plastic to make its flexible displays.But this is an expensive process, says New Scientist , because OLEDs are made at such a high temperature that the plastic mounting would melt if the parts were all made at the same time. As a result, the OLEDs are made on a glass surface and then transferred onto the bendy plastic afterwards, pushing costs up.
So instead, LG Philips' scientists have come up with a new way to illuminate pixels on a flexible display. The pixels are made from tiny plastic cells filled with minute amounts of oil and water.
The oil floats on the surface of the water and shrouds the coloured surface underneath it. When electricity is applied across the cell, the oil moves aside, changing the colour of the pixel.
[h3] Flexible displays[/h3]
The resulting display is apparently full colour and glossy, like the cover of a magazine.
LG Philips announced a 14.1-inch colour e-paper display in May, which uses a metal substrate instead of more conventional glass. This enables the display to be curved around objects like street furniture - handy for advertising and other promotional purposes.
tech.co.uk
1 - 1 of 1 Posts
1 - 1 of 1 Posts
