I've made a low buck subaru ev in Omaha.
An 83 subaru station wagon using the clutch, flywheel and 4 speed. 400 amp aircraft starter/generator.
This was done as a super low buck quick and dirty project. Junk yard parts wherever possible.
4/0 welding cable and 3/4' copper water pipe cable ends.
1/4" copper bus bar material for the controller.
200 amp 3 pole breaker. Paralled the 3 poles.
A fuel injection throttle body with 0-5K pot on it for the controller.
12 identical light truck 12 v batteries. Had terrific zap. Were probably in fleet service
and had been replaced on a schedule.
12" variac for the charger. For charging, I am connecting the 96 volt armature pack,
the 24 volt shunt field pack and the 12 volt accessory battery all in series for 132 volts.
I smoked the Paul & Sabrina's cheap DIY 144v motor controller that I made with 180 volts, and have since been driving it at 24 volts with a contactor control, strictly on or off. Actually not to bad.
Don't want to join any club, but am always interested in what other people are building.
If you want to talk, evenings, Larry 455-4957
