1 - 1 of 1 Posts
Ive found some low voltage alarms that should work from the BMS
connections for Chevy Volt packs.
trouble is I can only fit one of the devices(its 8S configuration) on the factory BMS connector.
So my plan is to use 6 pins on one(7 including ground) and 6 on the other.
So Im looking for similar plugs to add the second device.
It sure would be nice to find the same thing in a 12S configuration.
Im reusing the connector and wiring at the pack,just need to split the wiring at the other end
for the 2 8S devices.
1 - 1 of 1 Posts
